https://crackeddownload.com/product/cle ... -software/
ClearEdge3D Verity 2.0 crack license working tested
ClearEdge3D Verity 2.0 – Introduction for Professionals
ClearEdge3D Verity 2.0 is a powerful construction verification and scan-to-BIM QA/QC software designed specifically for architects, engineers, contractors, construction managers, and BIM professionals involved in building and infrastructure projects.
ClearEdge3D Verity 2.0 BIM CAD software
Verity enables users to compare as-built laser scan data (point clouds) with design models (BIM or CAD) to identify discrepancies, validate installations, and ensure field accuracy — all without needing deep point cloud expertise.
Overview
Verity 2.0 by ClearEdge3D bridges the gap between the digital design model and the real-world as-built conditions , making it an essential tool in modern construction quality assurance/quality control (QA/QC) workflows.
It works seamlessly with major BIM platforms like Autodesk Revit , Navisworks , and other AEC software via its integration with Autodesk ReCap Pro and supports common point cloud formats including E57, RCS, RCP, LAS, LAZ , etc.
Feature
Description
Scan-to-BIM Comparison
Automatically compares point cloud data with BIM/CAD models to detect deviations in real-world installations.
Automated Deviation Detection
Quickly identifies misaligned elements like walls, MEP systems, structural components, and architectural features.
Customizable Tolerances
Define acceptable deviation thresholds based on project specs or industry standards.
Clash Detection & Reporting
Highlights physical conflicts between as-built and design intent.
Markup Tools & Issue Tracking
Create, annotate, and export issues directly from the comparison results for coordination or RFIs.
Integration with Revit & Navisworks
Works natively within Autodesk products through ReCap Pro, enabling seamless workflow.
Point Cloud Navigation
Navigate large datasets efficiently with intuitive tools for slicing, sectioning, and filtering.
Export Reports & Visualizations
Generate PDF reports, screenshots, or issue lists with visual overlays of deviations.
What’s New in Verity 2.0?
The 2.0 release introduced several enhancements aimed at improving efficiency, usability, and integration into modern construction workflows:
1. Improved Automation
More intelligent alignment and comparison algorithms reduce manual input.
Enhanced support for large-scale scans and complex geometries.
2. Better Visualization Tools
Heatmaps and color-coded deviation maps for quick identification of problem areas.
Enhanced rendering performance for large point cloud datasets.
3. Enhanced Reporting
Customizable report templates.
Export options include CSV, Excel, PDF, and direct BCF (Issue Management) exports.
4. Revit Integration Improvements
Direct feedback loop: push findings back into Revit for clash resolution or model updates.
Supports more Revit object types and properties.
5. User Interface Enhancements
Streamlined UI for faster navigation and issue tracking.
Better support for multi-monitor setups and high-resolution displays.
