MMOexp-COD BO7: How to Abuse the Maverick’s Hidden Full-Auto Mode
Vous avez besoin d'un coup de mains ( autre que mécanique),
venez le demander ici.
Les membres qui peuvent vous venir aide n'hésiteront pas.
Chunzliu
ma moto : audio
Message par Chunzliu » samedi 29 nov. 2025, 04:06
Every year in Call of Duty, there's always that one weapon players overlook-until someone finally picks it up, realizes how absurd it is, and then the entire community collectively goes, "Wait… how has nobody been talking about this?"
In Black Ops 7, that gun is the X9 Maverick Call of Duty Black Ops 7 Bot Lobbies.
A hyper-consistent burst rifle that behaves like a full-auto beam when you hold the trigger, the Maverick is easily one of the most busted guns in the entire game right now. Whether you prefer crispy long-range bursts or fast-paced, aggressive entry plays, this weapon simply refuses to lose gunfights. And once you learn how to abuse its strengths, it becomes almost unfair.
This article breaks down everything about the Maverick-from attachments, tips, and recommended alternate builds to a full gameplay analysis featuring a wild, panic-inducing nuke run complete with drones, chaos, failed reloads, and existential Call of Duty rage.
Why the X9 Maverick Is the Most Broken Gun in BO7
The Maverick isn't just strong-it's effortlessly strong. It has:
No recoil
No horizontal sway
No gun shake
A near-perfect one-burst potential
A "secret full-auto mode" just by holding the trigger
As long as you're landing your bursts-especially with a headshot mixed in-you'll delete players before they even have a chance to react.
Unlike other burst rifles that make you time your shots, the Maverick fires so fast while holding the trigger that the distinction between burst and automatic is almost nonexistent.
The result? A weapon that melts entire teams and makes gunfights feel almost trivial.
Best X9 Maverick Attachment Setup
Here's the optimized setup that turns the Maverick into an unstoppable, one-bursting laser.
Muzzle: Defensive H Suppressor
Because the gun has zero recoil, you can skip compensators entirely. The Defensive H Suppressor gives smoother ADS and mobility-perfect for aggressive players who like to push.
However:
If you play slow, hold power positions, or let enemies come to you, the Monolithic Suppressor is also excellent.
It trades mobility for range, and with a burst weapon, range is everything.
Pick based on playstyle.
Barrel: Long Barrel (Shroud Barrel)
To keep the Maverick consistently one-bursting, you must maximize damage range.
The Long Barrel pushes the 3-shot kill potential out to about 22 meters-which isn't huge, but enough to keep engagements consistent. More importantly, it gives you much more reliable one-burst potential when combined with headshots.
Also: hold down the trigger.
Many players don't know this-the gun fires faster and more consistently when you do.
Rear Grip: Pillow Grip
You don't need massive recoil control, so the Pillow Grip gives a crucial ADS speed boost.
This lets you:
Snap onto players faster
React to flanks more reliably
Win tight gunfights where the slight ADS delay could otherwise cost you the burst
Even if you're not sliding around the map, faster ADS always helps with consistency.
Stock: Strider Overstep
This stock is secretly cracked. It gives:
+22% strafe speed
Better tracking
Better survivability
Easier one-burst accuracy while moving
The alternative is the HO 190 Full Stock, which helps with flinch resistance. But because the Maverick kills so fast and rarely gets you into drawn-out gunfights, the Strider's mobility benefits are simply better.
Optic: ELO Sight
This comes down to personal preference. If you like the irons, you get a free attachment slot-but the ELO helps maximize burst accuracy and track targets cleanly.
The gun feels snappier and more precise with an optic, especially when you're trying to chain one-bursts at all ranges.
Alternative Build: Overpressured Rounds Combo
If you're not running an optic, switch to Overpressured Rounds in the Fire Mods.
This combo (Long Barrel + Overpressured):
Removes bullet delay
Converts the gun into a near-hitscan laser
Extends effective range dramatically
Maintains one-burst potential far beyond standard rifles
Avoid Rapid Fire-it kills your bullet velocity, reduces range, and forces you to run compensators, which ruins the gun's strengths.
Gunfighter Eclipse Build (Max Attachments)
For players who love maximizing every stat:
ELO Sight
Long Barrel
Lock Stop Laser
Quick Stop Foregrip
Strider Overstep Stock
Pillow Grip Rear Grip
This build is insane for Warzone as well-expect it to be meta.
Secondary Recommendation: Velix Pistol
The Velix is the go-to secondary right now. Fast, reliable, and perfect for finishing burst-damaged targets.
Gameplay Breakdown: A Chaotic, Rage-Fueled, Insanely Close Nuke Run
Now let's talk about the gameplay-because this nuke was one of the most chaotic, frustrating, "I need therapy after this" experiences imaginable.Early Game: One Burst After One Burst
The match opens with instant deletes:
One-burst kills everywhere
Clean rotations
Perfect spawn trapping
A pistol finishing anyone who slips through
The player jokes about ADHD pushing them aggressively around the map-but with the Maverick, even reckless plays feel controlled.
The First Rage Moment™
Despite having 35 ping, the game starts giving him those classic Call of Duty moments:
Bullets not registering
Enemies appearing on every angle
Getting one-burst when he doesn't kill in one burst
Drones absolutely terrorizing him
Mid-Game: The Near-Death Sequence
During the nuke streak, several panic moments unfold:
Rockets flying from nowhere
Enemies spawning behind him
Random explosions shredding armor
Reloading in the middle of running away (his words: "Only idiot sandwiches do this")
Getting stuck in corners
Drones appearing every five seconds
He stops pushing and starts sweating for his life-classic nuke gameplay shift.
The Maverick continues to save the run:
Snappy one-bursts
Zero recoil laser tracking
Perfect pre-fire using laser accuracy
Wild strafe speed dodges
Final Score: 90-9 buy Black Ops 7 Bot Lobbies
All on the same map he always drops nukes on-because if you get a good nuke map, you never leave the lobby.
Final Thoughts: The X9 Maverick Is Undeniably Meta
After watching the gameplay, testing the setups, and breaking down the weapon's behavior… there's no argument.
The X9 Maverick is absolutely meta-possibly the strongest weapon in Black Ops 7.
Why?
Constant one-bursts
Zero recoil
Near-hitscan speed
Full-auto behavior if you hold the trigger
Insane consistency with the right attachments
Works for aggressive and passive players
Dominates in Warzone and multiplayer alike
If Treyarch doesn't nerf this, expect everyone to be running it soon.
Retourner vers « LES MEMBRES S'ENTRAIDENT »
